Im in the process of getting all the parts for an EDIS (electronic distributorless ignition system) Mod to my 1969 XW Falcon. I will be using a Megajolt LightJr kit, ignition advance control which can now be used to switch ignition maps from, for example, ULP to LPG.
Has anyone else done something like this to an older six?
I just need to sort out the trigger wheel for the crank sensor, Im having one machined at work and need to know some details about the harmonic balancer.
Yes I know I have one fitted to the car, but I dont want too have to remove it to get the measurements I need. Can anyone help me out?
I need to know the outside diameter of the bolt that holds the balancer to the crank, so I can fit the trigger wheel to the outside of the balancer. Also the distance to the other bolt holes from the centre and their diameter, so I can use one of them for anti rotation of the trigger wheel.
Any help is appreciated, Cheers
