FloridaRustang
Active member
OK, crazy idea, but let's assume I'm building an EFI system without a MAP sensor.
To elaborate, assuming that using the "gas" pedal varies the maximum lift of the valves rather than the opening of a throttle body butterfly, there's no real pressure upwind of the valves to give a reading on any MAP sensor. A carby worked in this situation because it relies on air speed, not vacuum.
My present line of thought goes like this:
For a given A/F ratio, an engine will settle at some optimum RPM level for the present maximum valve lift and air temperature.
At any given time, the RPM level is higher than, equal to, or lower than the optimum level.
What to do?
If higher, lean out
If equal to, you're right on schedule
If lower, richen up
Or is there a better way? MAF sensor? Or is my assumption off, that the MAP sensor won't function in this arrangement?
What to do?
If higher, lean out
If lower, richen up
