Sometimes when I start up (cold or hot) I here a 'knocking' sound. It goes away. I also get a similar noise when I'm in third gear (c4 auto) going slow up a hill and trying to accelerate. It seems to only happen at low rpm under load. Is this a timing problem or som other "serious" issue? I have no clue as to what degree from TDC my timing is set to. I've tried to set the timing to 12 degrees using a timing light in the past, but it stalls (my timing mark pointer seems to be misaligned). So, I just set it by ear (iterating between timing and carb idle speed).
Also, are c4 auto transmissions the same between 8 cylinder cars and 6 cylinder cars? In all of the parts catalogs I've seen, there is no differentiation between 6's and 8's. Are the "Shift Kits" the same?
Is there something in the transmission that could be causing this? I have a green-dot c-4.
