do you mean the hooks that are on your motor to lift it out with?is it a 200 x-flow?if so alot of xf's had them,should find a set easy.if its a pre x-flow just undo a exhaust manifold and a intake manifold bolt then put a 1 metre piece of chain on the bolts,do em up and pull her out,i've done this quite a few times and it works fine.don't know where u might find a set.
