blsstang":dhxi5zi0 said:
David,
I really appreciate the post. I was beginning to wonder if I said something wrong in my last post since I wasn't getting a response but a lot of views. I'm very new to using forums and am learning more and more everyday about my I-6 and D-tranny. Your right about the shifting. It shifts smoothly overall but does cluck hard into second when down shifting if you don't double clutch. Please tell me more about the vaccum. I tried installing a Petronix Ignitor and it worked except I can't seem to get the engine to run smoothly. I will read the stickies as you suggested. I don't have a lot of experience with major engine work, so if anyone knows of a good I-6 mechanic in the Green Bay/Appleton, Wisconsin area, please pass along their name and e-mail. Thanks again for the post David. I will check back regularly for further suggestions and keep you posted on my up-grades.
Blstang,
Welcome to the forum. No, you didn't say anything rude. What you have to realize, as I have over time, is that a lot of new users come on board and start in a similar fashion:
"Hi. I got a car with a 200 and want to hop it up. What should I do?"
You were definitely a little more informative than that and you showed some initiative by mentioning the Falcon Performance Book and Classic Inlines and Clifford.
A lot of time, the answer is "it depends". Depends on what you're starting from, what your goal is and what your budget is. Daily driver or show car?
For me, safety first in the form of brakes and good suspension. Then, from a motor standpoint:
Ignition, then carb, then inside the engine, then exhaust. That's just my preference.
I went all out on my daily driver and I love it!
DUI ignition
Oz-250 head and 2bbl intake
Brand new Autolite 2100 from Pony Carbs
Classic Inlines cam and headers
Magna Flow "wide open" mufflers off dual exhaust
Classic Air under dash a/c
I already had done the a/c and conversion from 3 speed manual to C4 automatic. While I'm happy with the tranny, I do pull high rpms on the freeway.
Anyway, enjoy the journey and utilize this website. Lots of great info here.
