Vaughan_D_W
Active member
Ok, first off, I'm an OTR truck driver, so I don't get home to work on my car all that often. I finally got the newly-rebuilt 200 in the Mustang, got everything hooked up, and I want to get it running next time I'm home. It's a pretty basic rebuild, nothing major. No headwork beyond new valve seats and replacing the valves that needed it, shaving the head a little bit, and shaving the exhaust manifold mating surface. Block decked, bored .030 over, crank turned, etc. Just a basic rebuild the way the nice, patient old man at the machine shop advised me to do it. This is my first rebuild, and I assembled the freshly-machined parts myself with a little help from a gaggle of half-drunk hillbillies. Sounds fun, right? Like I said, I got it in the car now, and I have a few questions.
1. It doesn't run yet! I hooked up the battery, and it was dead. I had just charged it, but then left it hooked up to my other new project, an '84 VW diesel, which drained the battery overnight. So there's a fun thing to fix on the bunny! But I digress. I tried the battery from my Dad's first-gen Scion xB (1.6 liter motor) and it acted like it wasn't getting enough juice. Turning over real slowly, making a popping sound, and getting the battery cables so hot they started smoking at the solenoid on the inner fender. So I got a new solenoid (or starter relay or whatever the hell you call it), and put a charge on the Mustang's battery. I also double checked to make sure I'm not out of time. Sometimes you have to double check things when your friends are half-drunk hillbillies. Then I poured a little gas in the carb and tried again. The bigger battery had it turning over faster, but still a bit slowly. The cables also didn't get as hot. It kept "popping," too. Like it was trying to backfire through the carb, but with no fire or big bang like a real backfire. Then my starter stopped engaging the flywheel. It just spins and whirrs now. So I figure I'll get a new starter and try again next time I'm home. Given this information, does anyone have any ideas? Maybe I'm not getting a good ground? I have the ground cable at the motor mount.
2. Proper timing. When I said I checked the timing, I mean I confirmed that the number one piston was at TDC at the same time the distributor rotor was firing at the number one wire. I don't know about setting the actual TIMING timing, if you know what I mean. I usually just turn the distributor until is sounds good, or use a stroboscopic timing light, but both of those methods require a running engine. Any suggestions?
3. Carburetor size. The car had a 144 out of a 1960 Falcon when I got it. I found a real 200 from a '67 Mustang to rebuild. I have the carb from the bigger motor, but I already know the Falcon carb works, and I've cleaned it, and the car is set up for it. I want to switch carbs eventually, but with having limited time and just wanting to get the dang thing running, I threw the old Falcon carb on the new engine. My concern is that, with the old carb having a smaller venturi, and being jetted for a 144, I might be running too lean for the bigger engine, and end up damaging my motor. Any thoughts?
Thanks for everyone's consideration. Sorry if these are stupid noob questions.
