My engine was running pretty well until I installed the Pertronix Ignitor 2 on the Ford 223.
Install went super smooth, replaced the coil with a Flame Thrower 2, new wires and new plugs.
Start up is quick, engine idles really nice around 550 rpm. Revving the engine in neutral produces a pretty even sound.
So here's the problem. When starting from a stop, somewhere in the low 1000's (I'm guessing around 1200 since I don't have a tachometer) the engine starts to stutter really bad and shakes sort of like someone just learning to drive a manual shift. I know my clutch is on the way out, but I didn't have these problems before and I can't imagine just changing out a coil and ignition would cause this much chatter. If I lay on the gas at this point, the engine will smooth out some where in the 2000's.
Thoroughly confused...
