I removed my exhaust manifold to repair a bad gasket and found a few questions to ask.
1) I had to cut the top bolt on the #5 cylinder. It has a nut on the back side. Is it supposed to be that way or was that originally threaded into the block?
2) I was planning on chasing the threads in the block and replacing the bolts with some new grade 8 hardware. Are the threads just 3/8" UNC?
3) Since the manifold didn't use a gasket originally, should I go back with some Permatex Ultra Copper or use a gasket?
Also, I found something interesting. I knew that the engine wasn't original so I looked up the casting numbers. The head is C1UE, best I can find is that it's a '61 Econoline Van. I bet not many Mustangs have that!
