All
I have a 1966 170ci Bronco. Engine was just rebuilt but we kept the exhaust manifold which visually looked ok. There are exhaust fumes coming in the passenger compartment and I suspect the manifold - the exhaust pipes are rust covered but I don't see any holes. I believe the PO installed a manifold from a 200 because with a 170 bolt kit I purchased, the bottom bolts were too short, so this manifold might have a bigger chamber ? - everything else lines up and from looking at the 170 gasket the ports appear to line up although I did not measure. Bolts were torqued according to shop manual instructions. Don't see any cracks although I have not checked for warping. Otherwise, does anyone know if a 200 manifold with fit on a 170 engine ? The Bronco currently has a 2" exhaust pipe not a 1.75" which also makes me suspect the manifold is a 200.
I can purchase new 170 manifolds and CJ Pony has a complete exhaust system (they say for a 170, but indicate the pipes are 2"). So the problem is matching a new 170 manifold (which takes 1.75" pipe) with a new exhaust which all I can find is 2". Reducers is a good idea but for 1.75 -> 2" is impossible to find (I assume one end is flared to 1.75 and the other accepts a 2" flared pipe?). Any suggestions would be much appreciated !
As a side note, here's a bit of information about a 170 manifold Bronco Graveyard sells (which is likely the same as everyone else's)
Made for the 170 Cubic Inch 6 cylinder, but will fit 200 cubic inch 6 cylinder.
NOTE: 170 has smaller exhaust ports than a 200 and that is what this piece uses.
Fits 170ci and will work -with modifications- for the 200ci 6 cylinder engines.
Tony
Tony
