exhaust manifold?
8)
I have one sitting on my floor.
I have also wondered about using that design.
The biggest problem in my mind is getting it to seal. The big hole is for a light off catalytic converter and IIRC the can sits on the edge of the hole and a big ring comes down and bolts to the studs and clamps the can to the manifold.
If you could find some way to make a big heavy cast steel plate that would fit the hole and have a T3 flange on one side it could possibly work.
This place can sell the flanges for a t3 but your on your own to make a adapter plate for that manifold.
http://store.racing-solutions.org/
Well,
By milling off that sealing suface so you have a flat piece to start with, and then welding or brazing on a T3/T4 flange, you could certainly turn that into a turbo manifold.
That is basically what I did, but with a '68 Manifold.
If anyone wants me to convert their exhaust manifold into a turbo manifold, just let me know.
The only problem with this approach is where it locates the turbo - it can cause clearance problems.
Bort62":3v4z72sf said:
Well,
That is what I did on my original turbo setup, it was with my old 68 manifold.
