kuhlou
Been putzing around quite some time locating vac leaks. After replacing hoses and plugging choke vac line and seeing some improvement, went for the carb cleaner test suggested in other posts. Sprayed the carb cleaner while idling, idle went up and smoothed out. So, something is certainly leaking vacuum. It seems to speed up the idle almost anywhere I spray it around the base, also on the carb body itself. I had the carb "rebuilt" last fall, though I'm getting quite skeptical about the rebuild.
Carb is an autolite 1100 non-scv on a 66 mustang 200 with non-loado dizzy, CA smog version. Plugged off the internal vac port also, as suggested in other posts. Dizzy vac hooked to manifold.
What items do I check on the carb to determine if there's a vac leak on the carb body?
Also, is it correct to assume that when the carb cleaner is sprayed, idle picks up and smooths out, that the leak is temporarily sealed by the carb cleaner liquid? As the liquid is sucked through the leak, the rough idle returns?
Finally, once vac leak issues are found, what is the correct procedure to set the idle. Set idle stop screw first, and then the mixture screw? I read about it in another post, and cannot find the post again.
Thanks for the help.
