Straight to the point -- my idle adjustment screw doesn't let me dial my engine down to the spec of 750 RPMs.
I have a Carter YFA that I rebuilt last year. It's attached to a 200 cid L6 in my '74 Bronco. The thing runs great but it seems to idle high (850 is the lowest I can get it), and to the point that the idle adjustment screw isn't even touching the stop. Here's what I have in the rig.
Pertronix I ignition
Pertronix I coil
Plugs gapped to .039 (spec is .034)
I've got it timed to 8* BTD (spec is 6* BTD)
I ran the idle mixture in all the way and then backed out 1.5 turns
I ran the idle speed screw just to the stop and then an additional 1.5 turns in
I disconnected the throttle linkage just to make sure it wasn't hindering anything
I've been trying to set the rig to best lean idle by doing the following. I hooked up a tach to my coil, as well as a vac gauge to manifold vacuum. I hook up my timing light, unplug the hose from the vac canister and plug it. I verify the timing is at 8* BTD. I unplug the line and hook it back up to the vac canister. I then start backing out the mixture screw while watching my tach. The tach wavers all over the place initially but starts around 750. I back out the mixture screw 1/4 turns and watch to see what my highest reading is. It will climb and eventually stay at 900 rpm. I then turn the mixture screw back in about 1/2 turn to get a drop of 25-50 rpm. At that point, I was hoping to use the idle speed screw to drop it to 750 or so. But as I've said, that idle screw doesn't seem to affect the idle at all.
I've used an unlit propane canister to check everywhere for vacuum leaks but I can't find any. I also removed the air cleaner, covered the carb throat with a rag, and the engine dies immediately, without a change in speed which I used as my second test for a vacuum leak. I have no idea if this makes a difference but I'm at 4,500' elevation.
I can just keep driving the rig since it runs so nice, but I can't sleep knowing that idle speed screw gets a free pass and doesn’t have to do any work. Once more I'm coming to this well of knowledge. Thanks much!
Pertronix I coil
