hey
ok they do fit and there a few in the xr xt falcons.
the manifold there is early multi point there is a later one as well with variable runners (one long one short) for better throttle and torque lower in the revs but dosent hinder up top as much.
the advantage is i think that it is mounted up higher.
you might want to check high and length as well as there are longer and a bit taller (id say about as tall as log 250)
engines mounts are different but can be mixed and matched.
i fited an earlyer engine to a later falcon with these engines and found if you can put the earlyer engine side mounts on the later rubbers so should be reversable or only need slight mods.
sump should be able to be rectafied with a 2 3lb metal movers.
if you get the earlyer block or an el falcon block one with the dizzy in it you can modify a earlyer xflow dizzy to work fairly simply i think its just turn the gear upside down this gives you a mechanical dizzy.
this is the same for the 4L doch engine which is same right through expect for the gas and turbo engine all with vct and 182kw in ba form and 190 in bf form from dual independtent vct on both exhaust and inlet (only a programing change
all mechanical stuff there for it on both engines)
if going 4L doch get a lpg one as they have a stronger rod and slightly high comp 10.2:1 or so
you will how ever have troble with sumps if you cant run it flat down as they are a cast alloy sump designed as bottom end craddel for the engine.
might be rectorfied with a 4x4 terry sump but which has the alloy sump moded to have a bolt up oil pan.
and they dont run a dizzy at all just coil pack.
as for which ones better the alloy 2v or the 4L soch about line ball 4L doch whould be better then the alloy 2V but will be a bit dearer once up and running.
4L doch lpg are selling for about $1200 aus
aftermarket compter to run it with vct is about $3000 aus this lets it still ratain the vct and be infinatly tunable if like at something like every 50rpm.
any other Q's ill try to awnser for ya
