flex-a-lite 133 fan w/ thermostatic control
kukm66
I was looking for a slim profile electric pusher fan since that is the only type I seem to be able to fit.
There is only about 2 1/2 " between the radiator support and the hood release lever which restricts the sizes available.
I found the Flex-a-lite 133 fan with thermostatic control that is 2 5/8" thick.
There several Maradyne types with about the same thickness
What brand and model number are you guys running?
after modyifing the support, i installed a Mr. Gasket 16", but you may want to run two smaller fans side by side instead. Check out the pusher style dual fans on any older Benz.
