just when I thought I knew everything ...
Dad/son picked up a nice C6DE Mustang 200 I wasn't using for a '66 BRONCO that had a 170/Toploader 3spd (4WD) . I kept the OEM 136T Flywheel and Bell with floor shifter 3 spd Toploader tranny as he had the complete '66 Bronco's. Bronco was reportedly a Toploader with Xfer case. He says the Bronco's 170 flywheel pattern was different and didn't fit my C6DE 200 mustang engine's crankshaft FW pattern (!) .
I thought all 170/200 crankshaft Flywheel bolt patterns were same and any Toploader would use C6DE/136T type 8-1/2" (?) clutch and earlier engines the stepped FW smaller clutch (7"?).
- Please set me straight as to Flywheel bolt pattern differences with 170 and 200 engines and if possible: Bronco apps' through years.
Thanks.
200:
Thanks.
200:
