arc_johniv
Over this past weekend I was driving my '63 Falcon around when I noticed the temperature rising at an alarming rate. I overheated the engine twice just trying to get home (hit about 250°). Got home, pulled the heads and sure enough... Valves were ghost white.
Rather than doing a valve job on that head. I decided to repurpose the head off my '66 bronco (since the engines are the same 170 and the bronco's getting swapped). Seemed to be a pretty simple bolt on swap with some slight accelerator reworking, but other wise went on fine. Go to fire it up, and the engine sound very slow when cranking. Checked the battery and solenoid, but they seemed right.
I keep trying but the engine won't start. I've got air, fuel, and spark; so my only other thought was compression.
Hooked up a compression guage, and to my suppressed I had 0 pounds on every cylinder! I checked the gauge on another project to make sure it wasn't the guage, and the guage was fine.
The valves and springs are off the bronco, but all the other timing parts are the originals from the falcon. Are the springs heavier from the factory? I took the valve cover off and cranked it so I know they all move and all the valves open...
Planning on pulling the engine and doing an autopsy this weekend unless y'all can think of a simple reason.
Any ideas? Rings got to hot and shattered? Different head design for a later year?
