MandarinaRacing
Hello All!
I'm trying to elaborate a chart with the most commonly used torque specs for our sixes. Hopefully this will be the last time I have to ask for torque specs
I'd really appreciate anyone who can help...
Alex
- Connecting Rod bolt / nut
Cylinder Head Bolt
Main Bearing Cap
Camshaft to Timing Gear
Engine to Trans. Bellhousing
Valve Cover Bolts
Flywheel to Crankshaft
Flex Plate to Crankshaft
Flex Plate to Converter
Pressure Plate to Flywheel
Oil Pan Drain Plug
Oil Pan Bolts
Oil Pump Mounting Bolts
Starter Mounting Bolts
Water Pump to Block
Thermostat Cover
Exhaust (Header) Manifold to Head
RockerArm Assembly
Alex
