Ford FE rocker arm ratios
JackFish
2K+
Can someone tell me if there are FE series rockers that have the same 1.52:1 ratio as the stock 200?
I have a line on some sets, and I seem to recall that the FE series came in 1.6 and 1.7 ratios, or something like that?
I don't want to pick these up if they are the same as the stock 200, so is there a way to measure or determine the ratio of these arms? Perhaps some casting numbers?
Not even close. I not100% which one is which but there are 2 ratios
Non adjustable is 1.72 and adjustable 1.76 I think.
do the FE rockers fit the ford 6's?
do you need the whole FE rocker shaft and posts ?
or do you fit the FE rockers to the fords shaft and posts
allways wondered....
brett
I've wondered too, so that's why I'm going to have a look at these.
The shafts are obviously shorter, but I'm hoping they're the same diameter.
I've been looking into using FE rockers as well, I've got a set here. The rocker shaft is much larger than the I6 rocker shaft. I've also looked into using 1.6 ratio roller rockers for 318 mopars.
JackFIsh,
Nothing is impossible. I looked at doing this at one time. There is simply too much wrong. You would have to either bush the FE rocker down or use 2 FE shafts pieced together. The distance from the center of the shaft to the valve tip is off quite a bit so new shaft stands would have to be machined offset. It seems like the push rod on the FE comes in at a different angle than the I 6. The alignment of the tip, shaft and push rod adjuster is way off. I'd look at a different solution.
