The oil filter EXPLODED, and the oil pressure gauge was ruined (stuck on 130psi on a 0-100 gauge - that means the needle when past all the way around) I did pump a LOT of oil - all over the engine compartment.
That woulda been somthing to see!!
Alex,
IMO, anything would be better than stock!!
Here a "sample" of the stuff I have....I'll put all of it on my website when I get a chance....
D1DZ-6211-A Premium rod bearings 200ci
D1DZ-6333-A Premium main bearings 200ci
D1DZ-6337-A Premium main thrust bearing 200ci
D1DZ-6600-A H.D. 60 psi oil pump 200ci
D1DZ-6268-A H.D. 5/8" wide timing chain & gears 250ci
C5TZ-6303-D H.D. truck crank 300ci
CODE-6565-B ball & cup pushrods 170-200ci
CODZ-6564-A Adjustable rocker arm assy 144-170-200ci
B6A-6513-A H.D. valve springs 170-200ci
C20Z-6514-A H.D. valve retainers 170-200ci
BF-32 Autolite spark plugs colder than stock 170-200ci
DZ-5002 68-74 Electronic ignition conversion kit
Wider rear brake pad 9"x2.25" (stock is 9"x1.5")
1966 Mustang convertible
1960-65 Falcon station wagon or panel delivery only
C3DZ-2001-A
Ford cylinder head casting numbers,
170 CID (2.8L)
1964-65 C4DE-6090-D C5DE-6090-A,B
1966-67 C6DE-6090-B C7DE-6090-A
1968-69 C8DE-6090-B C9DE-6090-C,D,J,L,R
1970-72 DODE-6090-A
200 CID (3.3L)
1963-65 C3DE-6090-D C5DE-6090-A
1969-74 C9DE-6090-M D3DE-6090-A*
1975-76 D5DE-6090-BA
1977-79 D7BE-6090-AB D8BE-6090-BA**
1980-83 EOBE-6090-BB E1BE-6090-CC**
240 CID (3.9L)
1965-71 C5AE-6090-A,C C6AE-6090-A,C C8AE-6090-D
1972-74 D2AE-6090-AA
250 CID (4.1L)
1969-74 C9DE-6090-M D3DE-6090-AA*
Ford NOS "Can style" tune up kits (DEPENDING ON APPLICATION),
170 ci
TKF-19
TKF-6
TKF-2
200ci
TKF-29
TKF-19
TKF-6
TKF-2
240ci
TKF-20
TKF-16
TKF-15
TKF-5
250ci
TKF-29
TKF-19
TKF-6
300ci
TKF-20
TKF-16
TKF-9
Steel shim headgasket numbers,
144-170 ci CODE-6051C
200 ci C3OZ-6051A C5AZ-6051B
250 ci C9DZ-6051B
Keep in mind......all this stuff is obsolete from Ford. But I use it when cruising ebay
all the time!!
