Frankenstang can't come out to play today
strat1960s
Well, I am glad I checked out my rear brakes yesterday. I noticed some Dot 3 dripping from the L/R brake drum while the car was at the exhaust shop. When I got it home I decided since I had a rebuild kit, I would take care of both sides and replace the wheel cylinders. These rear brakes were so "jurry rigged", it's scarry. The R/R side was missing the adjuster lever and a cable. The park brake cable levers are gone as well. I probably had no rear brakes. I have most of the parts on order. Any suggestions as to where I can get the park brake cable lever(s) from? I haven't seen any in my catalogs.
Merry Christmas.
Ted
if i remember correctly. you can pick it up at your local autozone. but i could be wrong. also, if not, check the brake parts sections of a good catalog, i've seen complete brakes parts from the drum down to the cotter pin. good luck.
