kukm66 Famous Member Sep 20, 2007 #1 I will have to install a few frreeze plugs on my Maverick. Is there a sealant that needs to be applied to the outside surface when installing these?
F fmartin_gila Well-known member Sep 21, 2007 #2 I always use # 2 Permatex, after making sure all the old crud is cleaned out. Fred
woodbutcher 2K+ VIP Sep 21, 2007 #3 Yep,same here.Clean the holes well,and use #2 Permatex(R) around the outer edge of the core plug. Leo
rbohm 5K+ Departed Member Sep 21, 2007 #4 8) i also use #2 permatex after cleaning the sealing surfaces. in fact when i install a screw in core plug i use #2 permatex.
