Jamie Miles
I have a 1980 200/SROD 4 speed in my '72 Maverick.. Engine has developed a severe oil leak around the harmonic balancer. I'm loosing about a quart of oil every 100 miles and the oil is getting on the pulleys causing the belt to slip so bad that the alternator will nearly stop charging. I removed the balancer and discovered there is actually a relatively deep groove worn into the shaft of the balancer where it contacts the front main seal. I'm assuming this happened due to a seal that's gotten old and hardened up, but it seems strange none the less.
How hard is the seal in the timing cover to replace? Will I have to drop the oil pan? Has anyone ever heard of a groove being worn into the balancer by the seal, or is the grove supposed to be there?
