Hi All,
My fuel pump looks pretty new, but theres a nice wet area below it, leading me to believe that's the origin of (one of) my leaks. Upon further investigation, I found that the metal hoes leading to the carb is wiggle-able, and squishes out grease? The nut is tight as could be though...
Just changed the oil and there appears not to be any fuel in my oil. Should I just replace it, put on a new gasket, or look for an o-ring?
(pls ignore the upside down bolt on the line)
Thanks in advance!
DrC
Thanks in advance!
DrC
