FloridaRustang
Active member
Just a start, I'm learning how to do 3D stuff.
2 x 34mm Intake, 2 x 34mm Exhaust, 92mm bore (3.62"), lift of .590 shown, peak of the pent-roof is 12mm. Can't remember enough calculus to estimate chamber volume. :roll: Gets the idea across, though.
"Valves" are just 50mm long cylinders right now. Will have to shrink them a bit for actual passages.
Using TurboCAD v7.1 (9.1 or 9.2 is out now, picked this up cheap), no manual or tutorials so the learning curve is steep. Can't save to STL format, but it can do JPG, DXF, and DWG (among others).
