Over the past few weeks I have been problem solving the "sputter" at low speed/RPM's found on my '68 stock 200. I have researched quite a bit about the '68 FoMoCo Distributor/Carb set-ups for that year. With the help of this forum and some great FoMoCo Obsolete part suppliers and the '68 Shop Manual, I have found part of the problem. I want to share this info with my fellow '68 sixers to help spare them the headache I have had...
In addition to the mismatched pre-68 carb (spark control valve) and '68 dual advance distributor, requiring no SCV, I also found that the centrifical weights on the ORIGINAL AUTOLITE distributor cam were 18/13 (A/T and M/T cars) with the 13 on the stop. On the two Motorcraft, A1Cardone rebuilds I have used, both the weights were 10/15 with the 10 on the stop.
I bought a NOS Ford rebuilt using the original Ford Part number and the weights were the original 18/13.
Although this does not have anything to do with my low speed RPM issues, it did affect my total advance numbers and high RPM operation. Although the advance curve can be manipulated by only the initial and vacuum advance to compensate for the lesser centrifical advance, I thought I would point it out for informational value.
I hope this helps!
Jay
I hope this helps!
Jay
