Slv49, I am building up a turbo-LPG 250. The engine's at the machine shop right now, but I am excited about how it should run. I got it all real cheap, too. I paid $25 for a good used turbo out of a local salvage yard (from a Buick turbo 231), and about $100 for a complete LPG setup off a Chevy 350 on eBay (minus tank which wouldn't fit my 66 Mustang anyway).
I plan a draw-through configuration. If you think about it, this makes sense, since all aftermarket LPG systems sold in the US through the late 90's are draw through. A draw-though turbo also perfectly mixes the propane with the incoming air, assuring an even mixture to each cylinder (which never occurs with gasoline).
There are a couple of things to keep in mind, though. First, the advance curve is different for LPG than gasoline. LPG needs a faster rise, but less total timing than gasoline. Also, even though LPG has a higher octane number than gasoline, it lacks the evaporative cooling effect of liquid fuels, so you can't really raise the compression ratio much above what a gasoline engine will stand.
On the flip side, turbocharging and late-model, low compression engines ('78 and on, IIRC) go hand in hand for making great torque and power. To harness all that thrust, I rebuilt a C-4 from a stout 302 to fit behind the 250, but am keeping my 2.83:1 8" rear end (at least until it breaks!
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
). A low numbered rear end "loads" the engine, which helps build heat and pressure in the exhaust system for spooling up the turbo quickly.
This car is a long-term project with lots of development still to be done, but I have enough turbo and high performance experience to be confident in the outcome.
Here are a couple of web sites you should be sure to save offline for extensive study and inspiration. The first web site highlights a recent Ak Miller turbo-LPG project:
http://www.truckworld.com/4x4-OffRoad/9 ... illys.html
This one looks at some of the subtle technical issues to keep in mind with turbos (not an LPG project, though):
http://www.hotrod.com/techarticles/42798/index.html
