GM Module with DS
powerband
2K+
I tested a GM type HEI module with Clifford re-curved DS distrib. out of the engine and it works spinning distrib shaft with my fingers -(ZZap - yow) using temp batt supply. Anyone using this setup have any comments on actual performance. ?.
http://fordsix.com/tech/engine/duraspark/duraspark.php
Willl the dropping resistance original coil feed wire run the module OK or does it need reliable 12V?.
Powerband
I am running it with the resistor still in place and it seems to work great, never had a problem with it.
will I actually notice a difference in the way it runs it I bypass the resistor? I was going to when I did the install but got lazy :oops: ran fine so I never got around to it
