I tested a GM type HEI module with Clifford re-curved DS distrib. out of the engine and it works spinning distrib shaft with my fingers -(ZZap - yow) using temp batt supply. Anyone using this setup have any comments on actual performance. ?.
http://fordsix.com/tech/engine/duraspark/duraspark.php
Willl the dropping resistance original coil feed wire run the module OK or does it need reliable 12V?.
Thanks
Powerband
Thanks
Powerband
