Shrinkdude
Bought a header from a guy off craigslist today. I paid $150 for this Hooker Super Comp dual outlet. Good deal or ok deal? The rust is only surface rust I can sand off of it.
Even the stuff rated up to 1200 degrees?Mustang_Geezer":uyghz3hj said:High temp paint out of a spray bomb will burn right off. Go to your local hardware store and get some stove black thats used for wood stoves and BBQ grills.
Later,
Doug
grocery getter":crq3cgtm said:Dude... that's good deal.
FYI, if your car is lowered, they'll scrape
Bort62":36l92lzh said:grocery getter":36l92lzh said:Dude... that's good deal.
Especially if you've got fat girlfriend![]()
Bort62":3nfcpdjc said:grocery getter":3nfcpdjc said:Dude... that's good deal.
Especially if you've got a fat girlfriend![]()
grocery getter":1o3pd00u said:Bort62":1o3pd00u said:grocery getter":1o3pd00u said:Dude... that's good deal.
or, two thin ones...![]()
Hmmm that gives me an idea. I work in the packaging field and we use heat tunnels to shrink down film around product. Normally the tunnels run about 300-350 but they can go up to either 400 or 500. The can says to cure @ 300 for 2 hours.rommaster2":inpg1cf4 said:From what i've heard if you have access to a big grill that you don't care about you can ceramic coat it yourself by spraying then cooking it and it will last for a long long time.
That said i don't have one that i can spare, but who knows maybe the free area in craigslist *shrug*. You just need to be able to cook em at about 400 degrees for like two hours or so.
I used the Dupli-color high heat ceramic paint rated up to 1200 intermittent(rattle can)Building that for Papa Smurf?
What sort of paint did you use?
