Got a spare 215-262 block plate?
addo
Top Poster
REDLINE 10K
(Assuming these three blocks use the same bellhousing.)
I need to sacrifice one to the greater good. It has to be pretty decent - not filed, milled, or battered. Light corrosion that would gritblast off, is fine.
Are all made the same thickness? Post with your input; we'll hammer out a deal along the way.
Thanks, Adam.
I've got one, if I ever make it to Dad's house. Its sandwiched between a 223/3spd. Should be straight and unmolested. I know for a fact that the engine/trans has been together since '91 (When I put it in the barn). Did you ever find a small 6 dual pattern plate?
If you are in a rush you will have to wait for one of our more expedient members, cause I work slower then your molasses on rust.
-ron
Hey! I added new molasses and it sped up! :o
Small plate is under control; it's costing USD$60 all up - ignoring the foreign draft fees etc. :roll:
The one you have would be good; I could probably arrange for it to return also after specs were locked in... But that would be some while.
Don't worry about it.
I mentioned that it hasnt moved in 16 years right? When I separate the engine from the transmission I will *hopefully* be putting the 223 directly in the '54. It had a 223 in it a long time ago (still sitting on barn floor in front of pickup). It really wont matter to me if it comes back or not, I've got it covered. Plus if I ever did need one I'm sure I could find another.
-ron
