MrMootsie":32zka3mc said:
put the baffled grommet in, still some blow by. I'm going to move to a heavier weight oil, I think. Real answer is new rings, but I'm just not up for that right now.
Hello MrMootsie,
I'm curious, I assume the CI aluminum valve covers do not have a baffle below the pcv opening (on the inside of VC) like the stock ones do, is that correct?
Probably a silly question, and guessing it's why you and Gene mention a "baffled grommet"; just wanting to make sure in case I purchase one down the road...they sure are sharp
On your blow by, have you done a compression test lately? Or considered the valve stem seals (notorious for leaking)?
I need to set aside a day to do some various testing on mine, fuel pump pressure, compression, and a leak down would be nice too...just gotta find the time. Thanks for any light you can shed on the above questions. Have fun
