I'm looking for hardcore Duraspark info. Please I don't want wiring diagrams, or how to convert info, I want technical info...
Duraspark I uses the regular cap? It's just a transistorized point ignition?
Duraspark II use the larger cap, and has higher outputs?
What's the difference between regular, duraspark, and TFI coils in regards to voltage, ohms. etc.?
What are the differences in grommets?
Blue - Standard
Yellow - High altitude/Economy
Red - California?
I've heard the red gives hotter spark, and it also has an automatic coil charge regulator, is this true?
There are white and black grommets, what are these used for?
What is the max rpm? I've heard, 8000, 6000, the distributor is only good to 6000, the module is only good till 4500? What's the real deal?
What's the lowest voltage a module will run properly on?
What's really inside them? Anyone have an equivalent circuit?
Is an HEI module better? Does it have coil dwell charge regulator? Does it give a hotter spark?
Blue - Standard
Red - California?
