Well I've recieved my new cam, springs (with dampers), teflon seals, etc... I have been working on the head removing carbon build up caused by my previous carb running rich (now fixed by new 32/36 carb) and smoothing out the combustion chambers to help prevent any further buildup.
I have a bunch of qustions I was hoping to get some help with.
1) Has anyone had the machining done to the head to install the teflon seals? The teflon seals have an inner diameter of 0.460" (~15/32") where they should go over the head's post which has a diameter of 0.635" (~5/8"). If so with what process did the shop remove the excess material and how much should I expect them to charge? Grinding the posts with a dremel would take forever.
2) The combustion chambers measure ~ 60cc, the block was bored 0.030" over, and I was using the 0.055" thick Felpro gasket. The compression calculator yeilds a compression ratio of 7.7:1 for this combination. If I have the head milled 0.050" (assuming 0.010" for 2cc reduction in combustion chamber volume. Any one have experience with this rule? Is it accurate?) the compression calculator yeilds 8.6:1 with the felpro gasket and 8.8:1 with the Victor Gasket. Since I am going for a good cruising engine and if possible would like to continue running 87 octane would milling the head 0.050" be recommended or could I mill more for a slightly higher compression ration and more power?
3) The intake valve has a ton of black build up on the intake side. I assume its from the engine running cold, too rich carb, or bad valve guides, but the head was remanufactured about 40,000 miles ago. The intake valve measured 1.750" in diameter and the exhaust 1.390 (D7, 1977 head). Can I just order the FSPP stainless steel stock replacement valves and install them with no further machining? The valve seat were supposed to have been cut when he head was remanufactured with a 3-angle valve job.
4) Any idea on how much to pay for valve guide replacement? Althought there is just the tiniest bit of movement possible. Any advice as to if I need them?
5) What do burnt valves look like? Are my valves burnt? and what do you do for burt valves if they are burnt?
Pictures are bellow. Thank you for the help,
Greg
Head before cleaning (head gasket still on):
http://members.aol.com/gfeing4935/cylinderheadbefore.jpg
Combustion chamber before cleaning:
http://members.aol.com/gfeing4935/chamberbefore.jpg
Head after cleaning and smoothing combustion chambers. It's not perfect, but much cleaner and smoother than it was:
http://members.aol.com/gfeing4935/headafter.jpg
Single chamber closeup:
http://members.aol.com/gfeing4935/chamber.jpg
New Valve Stem sitting on head post that needs to be machined to a smaller diameter:
http://members.aol.com/gfeing4935/seal.jpg
Valves. I was very surprised by the amount of buildup on the intake vale. What causes that?
http://members.aol.com/gfeing4935/valves.jpg
Greg
