Howdy Back All:
Michael- My definitions of a performance exhaust system varies, depending on the combination. With a cast manifold anything more than a 2" system is a waste, in my opinion. I prefer a Walker DynaMax turbo muffler. It is throaty, but not too load, and very effieicent. Opinions vary considerably on what sound is desired. Compression ratio and muffler placement both have an effect on exhaust sound. In general, the farther forward the muffler is the better the rap effect, and vice versa. What's your pleasure?
With dual outlet header, a 2" system and turbo mufflers.
With a single outlet header, and 2 1/4" exhaust system with turbo mufflers is very effective. The area of the tube is the difference- and heat build up and velocity.
Ludwig makes a great point about the pulses or slugs of exhaust. These pulses create a freight train effect and tug along the next. In the 60's great efforts were made to design perfect 180 degree exhaust systems. That design is not available for our engines, but the relatively long tube headers available are a big improvement over cast manifolds. Think of the exhaust as beginning with the combustion burn, the exhaust valve opens and hot, expanded air is looking for somewhere to go. It rushes out the opening exhaust valve, almost immediately it begins to lose heat and, consequently volume. What's to keep it moving? Another pulse hits it from behind and pushes it along. And the pulse evacuates the combustion chamber and creates a vacuum behind it, timed to coinside with the intake valve opening and a fresh charge of mixed Air/fuel is drawn into the chamber.
