Vin Man
Part of my rebuild was the Classic Inline headers. Mike supplied the headers, the gasket, and the stud kit which I installed and torqued according to specifications.
However, after only about 100 miles on my build, I've got a nasty leak coming from the header gasket area.
It has been suggesed that I have potentially one of the following issues:
1. A non-true header. I don't believe this is the case as Mike sells high quality parts. I did not inspect the header for trueness before I put it on, I assumed that it was flat.
2. A non-true head. This is not the case as I had it checked by machine shop that did the head work.
3. Improper torque procedure. Possible
4. Bad gasket - possible
5. Other
Nonetheless, I have to remove the header, check the gasket and replace. Problem is access. To get to header, the intake has to come off. Alternator may need to come out as well. Then disconnect the exhaust pipes from header, unbolt header and check.
I plan to use the Ultra Copper RTV on both sides of the header gasket when I do the repair.
What I would like your opinioin on is the following - would you do this yourself, or would you have the exhaust shop do it? They quoted me <$150 to do the work.
Benefits are they stand behind their work. If it leaks again, its their problem.
Drawbacks:
$150 versus about $20 in parts and my time. I'm guessing 3-4 hours.
I'd appreciate your vote along with any comments or suggestions you may have.
5. Other
Drawbacks:
