66200i6
Check with Stewart Warner and find out what the readings should be for the sending unit. You can also check the gauge in the same way based on their specs. Confirm the gauge reading when your running is correct.
T-Stats have been known to stick open. That would explain the cold temps at idle but not the high temps at cruse. A clogged block would cause warmer temps at cruse even with the T-stat open. I wonder if you had two problems?
I'm sure something like that has never happened to anyone else before.
Ric.
Ric.
