I need help!
I just put a remanufactured engine into my 66 Mustang straight six 200, hooked everything up, and no leaks....followed the instructions to the letter and then turned the key and it wouldn't start. As I worked to find the problem I noticed that the carb (air filter off) was literally pooring gas out of the uppermost holes into the top of the carb. I unhooked the gas line to the gas pump, and after trying to start it for a couple minutes, the engine came to life and ran pretty well until the gas in the carb ran out. When I hooked the gas line up to the fuel pump, and tried again.....same thing. The carb is spewing gas down the throat in voumes, and then sometimes spitting some gas up in the air.
I don't know what to do.....I have come so far on this project, and now I can't get my car going. I have the stock Holley one barrel carb, I can't find any numbers on it. The only thing I can think is that when I had the carb off of the old motor, I had it about an inch above the workbench and it slipped from my hand and landed on the bench. Everything seemed to be fine, but maybe I dammaged something?? What do I do?
Any and all help is greatly appreciated.....
Ryan
Ryan
