My 69 Falcon 200ci isn't vacuumed correctly and I don't think I have any advance action.
The hose from the inner vacuum tap goes to what I believe to be the distributer vacuum control valve located in the thermostat housing. There are no other taps or connection on the control valve, it appears to have had the other nipple(s) broken off and siliconed over.
The hose to the outermost hose goes from the distributer to the carb.
There are no connections to manifold vacuum and I can't find a intake manifold tap to pick up vacuum, it's a D7 head.
My question are:
can I skip the vacuum control valve altogether
Can I run a hose directly from the inner diaphragm to the carb, and
run a hose from the outer diaphragm to the manifold
And finally, any idea where to pick up manifold vacuum?
Thanks in advance.
Stephen
My question are:
Thanks in advance.
Stephen
