Three important things:-
1. The heat stove under the carb rasies the fuel octane needed by 8 points on a Mini engine. How much morw with our log head sixes. If you have a Clifford port divider, there is less heat soak, with a set of headers, even less.
2. The second point is what David Vizard has siad for years. I haven't done the sums on the peak flow of 50/50 water alchol or just straight water at 45 psi with two 15 thou jets, but that will allow you to go to 12:1 compression with
no knock if the set-up can add water evenly at low manifold vaccums (excluding when cranking on startup!). The use of an adjustable pressure switch or MAP sensor is the trick. I'd look at the 2-bbl carb setup which mounts to the log like the
Mustang Geezer. The idea of single point dispensing of water worries me, as the cylindrs to detonate first are no 5 and 6, and they would be starved with a stock 1.75 or 1.5" log head unmodified. The H2o must mix into the atomised fuel, not under it. I guess you could make a set of brass port injectors, and run it like an EFI system, but I'm a bit a head of myself here.
3. Water injection never reduces pressure or heat at the exhast... it goes up. The piston may not be able to cope with 12:1 comp, even if the car doesn't knock. There is an emperical formula for the bulk thickness of a forged or non-forged piston, and if you over step the mark, it'll get killed dead. This goes for the block, head gaskets, ring lands, everything that seals is subject to more pressure, and there is a simple list of things you must know before you overtax the engine.
There is a chart used on the Pinto OHC and Mini A-seires engines from yonks ago, and this traces octane demand from the effective compression the cam provides. As
Panic says, the key is what the effective compression is. Cranking pressure is an indicator only. The Indicated Brake Effective Mean Pressure curve is the key instigator of pressure. The hard edges and the four items Panic mentioned last week on the power developed in high compression engines is pivotal in the point at which detonation sets in.
As we discussed it, some engines love to go stratospheric on compression, others hate it. Untill now, I've believed that there is a proportional gain, but there isn't at all.
I favour the algorithim approach jack describes. The key ingredients were shown by Whittey in a post long ago, and by Panic.
I can get the stuff from my books and chart it. Then come up with a first cut. The basic cannon fodder is here on these links.
Read and feed!
Panic's gem on why high compression doesn't give proportional increases in power
http://victorylibrary.com/mopar/otto-c.htm
Then the henpeck of it
http://fordsix.com/forum/viewtopic.php?t=12838
Effective compression calcs. Hey Panic, spot the error first starter for ten...
http://fordsix.com/forum/viewtopic.php?t=5518
Whittey found a better source of the calcs..
http://cochise.uia.net/pkelley2/DynamicCR.html
