Fairlane Fixer
Having a weird problem.
1904 holley, 200 I6, 2-speed fordo
This is a great little carb; easy to tune, adequate funtionalbility.
Runs great except after a few minutes, when car is at normal operating
temperature, on most left-hand turns carb tries to flood out. I can pat the
gas and once it goes straight it runs very well.
This does not occur on right turns.
What would be the likely culprit:
1. Engine heat causing fuel boiling which lowers fuel supply
(gas inlet is on the right, so fuel in bowl is leaning away from supply)
2. Could actually be starving for fuel (not flooding) float too low.
solutions? Make some sort of heat shield. Adjust float.
Thanks All
Thanks All
