Hi,
I set my timing and adjusted my Holley 1904 carb and I cannot get the car to idle correctly. First, the manual states that you turn the mixture screw back 1 1/2 turns and then turn it in to adjust. I have back the screw in at least 3 turns to get it to idle. I also have to turn in the curb idle almost all the way with the fast idle cam completely off of the screw, not on the last step. It also sputters and hickups bit, but not bad. I put in new ignition parts(points, caps, etc.) and rebuilt the carb but it did this before I rebuilt it. Could it be a timing issue? Maybe fuel pump? Hopefully I am not adjusting it correctly.
Thanks,
Pete
Thanks,
Pete
