This unit is sold, see another below.
Holley 1940 carb for service replacement of Autolite 1100 or upgrade. This model has the non-SCV vacuum port that that works with the dual centrifugal/vacuum distributors. Such as ’68 or later dist, or early IMCO with cent/vac advance dist. Not for use with ’63-‘67 Load O Matic distributors.
Port provides timed/ported vacuum. Hot air automatic choke.
Original manufacture by Holley in USA. Part number 4694 2, 0816
Cleaned, and rebuilt with all new USA internal components and gaskets including a new brass float. Includes new mounting gasket and fuel filter. Also has the brass fitting for vacuum port, and alternative barbed fitting (rubber vac tubing) and air horn adapter for use with early air filter housing. 1-7/16 “ bore.
Generally used on a Mustang 200 six. Complete, adjusted, and ready to install.
Note: Readily replaces the Autolite 1100 non SCV style. Some bending of lines is needed. If an original Autolite 1100 SCV is replaced, a dual centrifugal/vacuum distributor is required for use.
$220 plus $15 shipping SHIPS TO USA ONLY
PayPal/friends or money order
14 day refund, buyer pays ship back. SOLD see another below.
Direct Message me with any questions. Thanks
