Looking for dimension specification of flange base gasket dimensions. - Holley 2300 series carb - 7448 350 CFM version :
Need to find someone that can cut me a gasket shaped steel flange @ 3/8" for the 2300 2bbl. Interested in trying to fab a 'top hat' adapter. The steel plate 2300 base flange on top for carb and a short steel tube welded to the bottom plate flange adapter for the cut intake log. Intake would be modified for bolting on '2300 'top hat' adapter or alternate carb setup.
Basically I want to weld a short @ 2 X 4" steel tube between two steel flanges thick enough not to easily warp/distort . (wsh I could weld alum.... )
similar to this design :
The small block log manifold carb port usually needs any larger carb raised off manifold to clear VC and linkage and a short 'adapter' could easily maintain correct rear tilt with enlarged log manifold entry.
thanks
thanks
