Just a bit of technical advice for you owners of engines with the holley 2300 2bbl or any holley 4bbl with the automatic choke option with this adjustment feature.
The adjustment is for the choke pull off. Many of you possibly have no idea what i'm talking about. When you adjust the choke housing for the proper tension, there is another adjustment many owners are not even aware it exists,
The adjustment is after you start a cold engine the choke blade has to be cracked the correct amount. If the setting is too rich blubbering & black smoke will follow after a cold start, then go away after several seconds or minuites after starting-the other extreme is too much choke pulloff or choke blade opening after startup causing a lean stall. Remember i'm assuming your fast idle cam setting is correctly set.
This setting is on the choke casting. If you are too rich back out the small screw adjustment till the choke blade opens the proper amount to prevent the rich blubbering after cold start-up. If you have a lean stall after start-up you can turn the adjustment in clockwise to slightly close the choke blade for proper richness.
IF YOU MAKE THIS ADJUSTMENT FIRSTS CLOSE THE CHOKE BLADE MANUALLY THEN TURN THE SCREW IN OTHERWISE DAMAGE TO THE CHOKE PISTON IN THE HOUSING CAN BE PREVENTED.
Take a look at the photos & the adjustment screw will be obivious.
Hope this helps many of you holley owners. William
