holley 2300 throttle linkage???
matt1967
ok, I'm using a Holley 2300 with an adaptor from transdapt- log head. now I know I'v got a kickdown linkage also to deal with. What do I do for that? and what do I do to get a throttle cable hooked up? car is stock '67 Ford Falcon
matt,
I used a stock cable off a 300 powered EFI bronco (super long) on a fabbed bracket I made up (just some .100" plate I cut and welded up) using a fox tbird pedal but it fits kinda crappy and once I get a chance I am making up a custom one (IE hacking up the stocker and reworking it)
can't help you on the auto as I always run manuals.
I used the pedal assembly out of a 91 Grand Marquis. I'm sure the Crown Vic one is much the same.
.........Cheers, Alex
they are the same car but, I don't know if there were diffrences from '88-'91, was the '91 a 5.0 boxy looking car or the newer rounded style with a 4.6l?
