Clarification and suggestions for use with mechanical (stock) FP and tri-power carb setup. (Holley 1904's). I had a Mr. Gasket adjustable , worked but eventually diaphragm leaked, not going there again.
Both Holley items seem low pressure, I thought there were only FI(high) or non-FI (low), what's the diff' ?
(Summit vendor) :
12-803 - High-Pressure Fuel Regulator (std. finish)
---------- 4-1/2 to 9 PSI ---- 3/8” NPT Ports .220” (7/32”)
12-804 - Low-Pressure Fuel Regulator (std. finish)
------------ 1 to 4 PSI ---- 3/8” NPT Ports
Mr (leaky) Gasket:
(Summit vendor) :
Mr (leaky) Gasket:
