R random hero Active member Jan 17, 2007 #1 i have a ford 200ci in a 1972 ford maverick, i believe it's a motorcraft carb, not sure what model...any help?
B Bort62 2K+ VIP Jan 17, 2007 #3 That only adjusts the idle mixture. In order to adjust the mixture at other points, you need to change the jet/jets. However, unless you have modified it you shouldn't need to do that. The idle mixture screw will allow you to get your idle A/F dialed in.
