Lets start at the begining. Last week I found a local shop that offered to produce any billet part I can dream up. Including (but not limited to) carb adapters, water pump pulleys, timing chain covers, big block side plates, air cleaner tops, etc. The list could go on and on, and even include custom wheels if I desire, as they have that capability.
My first thought was carb adapters because of all the recent topics on them. My thought is to produce a two barel adapter that mounts to the log without milling, or reducing the intake to a 1V. Which means I need to do one for each style of log for proper fitment and seal. Of all the adapters I've seen, none approach it in the mannor I'm thinking of, or are 100% correct for any given application. Does that make any sense?
Instead of buying one of each, I plan to take modeling clay and make a pattern of the log, just over the carb location. Then I will make plaster molds of the various logs, from the clay patterns. Once thats done, I'll have lots of cheap and workable molds to play with, and will see what I can come up with. Then its a simple procedure to make a cad drawing of the piece and have them machined.
Could it really be that easy.
