Howdy Back Falcon 64:
It may help some and it looks cool as a ditch digger knee's in December. If you could figure a way to split the thing in the middle, separating the 3/4 siamized port in the head and the manifold, that would be better. Either way, it would likely reduce back pressure in the exhaust manifold, but without seperation, it would likely disrupt flow. The long primary tubes of a header system actually enhance the pulses.
The problem with a log manifold is the tight angle turns the exhaust pulses have to make both inside the head exhaust port and exiting the head and hitting the log. Exhaust pulses don't like to turn. Each hard turn disrupts pulse magnitude and velocity, which weakens scavanging and impedes flow. Picture this- the exhaust pulse has left the #1 cylinder and is head out the port. Oops, it hits the top of the exhaust port and has to turn down. Oops, it makes the turn then hits the exhaust log and has to turn back. Oops, it crashes into the # 6 exhaust pluse coming forward. I use the #s 1 & 6 cylinders because they are 180 degrees opposite, and should help each other. Headers elininate the 2nd and 3rd Oops'.
The exhaust ports are as bad on this head as the intake ports are good.
The advantages of adding a dual exhaust system is dependent on how restrictive your current system is. I'm wondering if a bifricated exhaust, cylinders 1,2,3, and 4,5,6, would ever generated enough heat to flow good and burn out the H2o resulting from condensation. Inner pipe diameter would be a factor.
Personally, I prefer a ported exhaust manifold, into a 2" system to a turbo
type muffler with one pipe in and two out, to give the look and sound of duals. It is a cheaper, lighter system, and possibly more efficient then a split log manifold and duals. Port match the individual window to an exhaust manifold, or slightly larger, and open the outlet to a full 2", but leave a ridge for the header pipe fire wall to butt against.
People who have done the split log duals report a great six rap, with glass packs.
If you go that way, be sure to report the results. Take a 30 mph to 60 mph timing in high gear, before and after.
Happy New Year.
