Just added a/c to my '62 Ranchero 170 (yippee!)
The kit uses the original 1-groove crank pulley to drive the water pump then a/c compressor, and the (new) alternator is driven from the a/c compressor's 2nd pulley groove.
Problem is, I've got the a/c compressor pretty darned tight (about 3/8" deflection), but the belt still slips a second or two when it engages, because the water pump pullet is deflecting "just enough" when the initial load "hits".
1. How much can I tighten the a/c and w/p belt before I start causing problems for the water pump bearings?
2. Is there a heavier-made w/p pulley out there I could look for?
3. Should I look for a 2-groove crank pulley, and engineer a way to have the crank pull the a/c compressor directly, without loading the w/p?
I like to run belts my belts on the loose side, the idea of a REALLY tight belt eating away at the water pump bugs me. Or should I not worry?
